- TENNESSEEESSEEEEEE
- Limitless
- Mojave
- Typhon 6s
heres a little update for whoever cares.
i have a 1300 foot road that is private right next to my house, so in the next couple of days, I’m going to try to get it out for a 105mph test drive on 6s, running 39:34 gearing, i expect this setup to do much more even on only 6s, but i will take your advice, and for the Time being, set my goal only 5mph higher then the last, one i feel fully confident with the last speed milestone.
my thoughts on how the car has been preforming are this.
as i have mentioned in the past, on the 2050kv, i did 91mph on 2 3s 100c lipos, and the car went absolutely arrow strait, and got up to that speed quickly, but still smoothly.
on the 1100kv, i did 55mph with a 50c 6s lipo in only 480 feet of room. Keep in mind i only hit about 85 percent throttle during the pass, and the remote was on 75 percent throttle limited.
going to get a long range radio now, since i am truly on a crap radio, a spektrum dx3 w/ sr315.
wanted to get it out for some test, and my plan is to move to a radiolink rc6gs v2, then either a futaba 7PXR or a fly sky noble pro, issue is i can afford either right now.
ill most likely try to bind with a spektrum SR6100AT reciver before i go and do 105mph, but if i can’t, i trust the SR315 for only 625 feet of room (with me standing in the middle and stopping a little early.)
as for other things i have not covered yet, have some carbon fiber side skirts on the car, even tho I’m still on the open wheel shell. I have a ford FC100 shell for the car, but I’m waiting for arrma infraction body posts.
also have the raz shifrin wing on the way, it will arrive in the next few days.
question: with basically all of the stock wing taken off (everything but the outer 2 fins) and the front wing off, will the car do something like backflip at 105mph with the stock shell?
Removing the wing wont make it flip, but it may fishtail due to reduced rear traction without the wing....
You may want to consider getting a signal booster. No matter if you go with the Futaba or Noble later on you will end up needing it.
