Would like to extend the length of my rc
BashTillBroken
Hospitality Award
Coming around to lap you AGAIN….. (Oregon)
  1. Granite Grom
  2. Infraction
  3. Kraton EXB
  4. Senton 3s
I have an axial scx10 ii and I want to run gladiator links to be able to run a certain body, but was wondering if they would fit because the gladiator runs portals and that might effect how they mount. Are there other options for lengthening my car or am I stuck?
You'll need to check the actual mounting positions on the axles and on the chassis. (Size width ect.) Then you ll need to make sure your driveshafts extend far enough to handle the added length...make sure they don fall out.
Just curious here because I don't know anything about the SCX10.ii. However I have the SCX1O.iii and the way the chassis is made, it's only a matter of 4 screws to switch between LWB and SWB. Are you sure you need to lengthen the chassis? The Gladiater is made to be a SWB(313mm). Not sure how that translates to your model..
with the scx10ii, you can move the shock mounting location further back and get longer driveshafts and rear top and bottom links. you can shorten or lengthen the rear links with different rod ends to get the axle straight.
Where do I get the longer links can’t find any for the scx10 ii
