Would these wheels fit a std Typhon?
Ari33
  1. Typhon 6s
I'm looking for a wheel tyre combo for more ground clearance on grass without totally going down the trugify route so that I can swap back super easy.
These ZD monster truck wheels have the 17mm hex and look to have a pretty huge mount offset, it doesn't say what it is.. but its more than half from the outside of the wheel.
If I reduced the steering throw and braided the tyres to stop balooning do you think they would kinda.. sorta work?
....Or just explode? :D
https://m.ebay.co.uk/itm/2pcs-3-6-I...e&pageci=df3fc110-7755-4987-af1c-ed65fdcb17ae
No good...those are large... they are bigger than a backflip lp... 150mm o_O
Thanks for your input.. can you elaborate?
They have very large offsets and I've taken some measurments and it looks like they will clear the body at the front.. and wing at the rear.
Maybe I'm being dumb... What am I missing?
You will not be able to change the gearing enough to compensate for that kind of tire... way way way way to big...
