Typhon Would this fit the Outcast / Typhon / Senton?
As long as the one end fits in the center diff cup and the other end bolts into the output from the diff pinion.
It's the correct length, but who knows what size Kyosho diff cups are and what the diameter is of the output shaft.
I know HB racing axles will fit in the diff cups but the center cvds won't work because the diff pinions are larger diameter.
Thanks, but I'm overseas :/ I'll keep looking for a shop that has all I need (front and rear, a 35mm fan for the stock ESC, the right tires and some parts for my Tekno) to avoid shipping charges by having to use 3 shops.
Oh, if your local hobby store has the diff outdrive ask if you can measure it and compare it to the Arrma, iirc the Arrma is 5mm.
