To add to this.to be honest I would - C rating has been skewed so much over the past years that you cant really trust it anyway - when searching for 50C+ for my 700/800 size helicopters hardly any we tested actually had more than true 45C ... different noname, brand names and "premiums" all seemed to fail the tests when using proper measuring devices we had to hand ... I'd say go for it ...
I have a 4S 5000 battery with 30c. Battery is new. Charged fine. Would it work in typical driving situations or would it cause issues not being at least 50c?
It depends on your current loading requirements.
This is all on paper here and doesn't really work like this in the real world because the C values are sort of fabricated by each manufacture. But just for fun let's pretend they are all equal.
C rating equates to how much current the battery can deliver and is proportional to the capacity (mah) or size of the battery. Basically if you have a small battery you need a higher C rating to get the same current.
Let's say current requirement for ESC is 160A.
Now using this formula below, we can calculate your battery requirements.
Crating=AESC_req*1000/Bmah or moving stuff around Crating*Bmah/1000=AESC_req
30C/1000*5000mah = 150A. It actually works out to 32C is required, but with round numbers it will work.
But bigger picture this means 30C @5000mah both can work but a 50C @3200mah can also work.
Oh, it's a very old thread! Not sure how I ended up on that one?Double check the last post date before commenting. This conversation/thread was last replied to 2019....
The real problem is that you don't know the C rating of the battery unless you have a load tester. All the advertised numbers ALL OF THEM are wrong.
