wadedog
That’s what I was told about the hoons I was just looking at the set that I ran last night and one is starting to separate that answer that for me
I check temps often I went up on the pinion hope to get to run after work todayJust increase a pinion tooth or 2 when you go to the smaller diameter GRP’s and keep an eye on your motor RPM’s and temps.
Had to work overtime today but I’m going to test on Saturday will keep you posted. Thank you for your informationI check temps often I went up on the pinion hope to get to run after work today
I finally got to make a good pass today went down 2t on the spur back to back 98.8 mph was still looking for 100 not so ezHad to work overtime today but I’m going to test on Saturday will keep you posted. Thank you for your information
