That’s not a given just because it’s being fed a higher voltage. It could be, but it’s not a given. Also, spinning faster doesn’t always mean more air movement. Number of blades, their size and pitch, all have way more to do with air movement than speed alone.my intent was to have to spinning much faster than it would when plugged to the receiver.
Being an engineer then you should know that a motor rated at up to 8.4VDC @ 15,000rpm is not likely going to hold up very long at all on 6S (22.44VDC). Why would you need a fan to spin faster than 15,000rpm?none of the things you listed are a factor in this since im talking about just 1 fan in both scenarios. just needed to know if that fan could handle straight s6. im not an electrical engineer but i am a mechanical engineer lol so im well aware of fan speed not being the only factor in moving air.
Yup that's mainly why I wanna know if anyone's done this and the WTF motor is capable of running like that.Being an engineer then you should know that a motor rated at up to 8.4VDC @ 15,000rpm is not likely going to hold up very long at all on 6S (22.44VDC). Why would you need a fan to spin faster than 15,000rpm?
