fcoolj
Hi All,
So I’ve been running my nue 1530 1580kv .75Y with mmx8s in my limitless with no dramas - 50+ passes, 139mph PB. Looking at logs i was exceeding amp threshold so decided to upgrade to the xlx2.
However, on my first run I kept getting motor start failure errors in logs. Car would seem like it’s cogging then reset. Thought it was a loose wire/bad solder. Checked everything was fine.
Ran it again the next day and it did fine. Ran it the day after and motor start failure happened again. Then blew my motor up. Do I have a bad xlx2? Or was my motor on the way out?
Anyone else experience this? Any help appreciated thanx!
xlx 2
Nue 1530
Cap pack
8mm bullets
Cnhl 6000mah 70c
xlx 2
Nue 1530
Cap pack
8mm bullets
Cnhl 6000mah 70c
