StephenSchandelmayer
Rig of the Month Winner
So I decided to make a LWB composite chassis even longer. I currently had the LWB on my truck and had a spare SWB on hand. I cut a 4 inch piece from the center of the SWB and then cut the LWB in half. I used aluminum sheets on the top and the bottom of the truck with nuts and bolts to secure all 3 pieces of the chassis together to make one huge XXL chassis. My favorite part of it though is the center driveshaft. I took 2 of the SWB shafts and took the spring out of one of them and then I slightly trimmed the spring on the second. I used one of the red splined connectors to connect the two in the middle. I also used 2 of the high speed bearing supports in order for it to stay nice and rigid. I'm using vorteks rear shocks on the front, granite rear shocks on the rear, vorteks rear tower and body mounts and granite front tower and body mounts, and granite front bumper. Also running typhon wing and arms.
I for sure added some weight with the aluminum sheets but I knew that was going to be part of it. Haven't even run it yet but I'm very excited to! BLX185 Esc, hobbystar 4074 2250 kv motor with 20 tooth pinion, 4s battery, full arrma metal diffs, M2C motor mount, metal spur, HR yolk on the rear diff, HR hub extenders with Badlands.
I had a lot of fun putting it together, hopefully it runs good! Kraton 6s for size comparison.
