Granite ZD shocks installed
quad_rocket
read around various posts and youtube and heard these fit. i just put them on today to replace the leaking stock shocks (n)
some people talked about using nitro tubing to help mount the top of the shocks, but when i searched for that it was some ridiculous amount for some ridiculous price and i only run electric
so i used some of these wire shelf end caps with a hole drilled in the middle
hope to get out and test them this weekend
https://www.banggood.com/2PCS-8002-...p-1436241.html?rmmds=myorder&cur_warehouse=CN
https://www.banggood.com/2PCS-8001-...p-1436245.html?rmmds=myorder&cur_warehouse=CN
I used fish tank air line for a bushing and it worked good, however the axial bushings that supposedly work are in stock at Amain I might order some. I didn’t shorten the rears either, I did it and hated the feel of them so went back to long length. Truck has a little rake to it but not obnoxiously so. Definitely need heavier oil than what came in them and an additional wider washer under the piston to keep it from punching through the piston.
https://www.arrmaforum.com/threads/zd-racing-shocks.20217/post-346805
I used fish tank air line for ambushing and it worked good, however the axial bushings that supposedly work are in stock at Amin I might order some. I didn’t shorten the rears either, I did it and hated the feel of them so went back to long length. Truck has a little rake to it but not obnoxiously so. Definitely need heavier oil than what came in them and an additional wider washer under the piston to keep it from punching through the piston.
Thanks for the direction and I see the rub now too.
