Typhon ZK's Typhon 6s Log
ZooKeeper
Quack!
ArrmaForum Fan
Chicagoland Burbs
  2. Granite Mega
  3. Infraction
  4. Kraton 8S
  5. Senton 3s
  6. Typhon 6s
I'm currently in the process of performing my annual winter maintenance on my Typhon 6s. Perfect time to start a maintenance/build log for it.
Below is the list of parts that I've changed or upgraded from the stock out-of-the-box configuration:
BrandPart #DescriptionLinkNote
ArrmaAR310484Wheel hex aluminum 17mm (16.5mm thick) redLinkKraton Part
ArrmaAR330404Hub RearLinkKraton Part
ArrmaAR310591Wheel axle 8x45mmLinkKraton Part
ArrmaAR330505Composite steering block front 6sLinkKraton Part
ArrmaAR310590CVD axle 8x44.5mmLinkKraton Part
Scorched Partsn/aSWB Titanium ChassisLink
Scorched Partsn/aTitanium Shock TowersLink
Hot RacingAON28C01Aluminum Front Chassis BraceLink
Hot RacingAON30X01Aluminum Rear Chassis BraceLink
Hot RacingAON1101Aluminum Differential Carrier CaseLink
Hot RacingAON50THardened Steel Mod 1 Spur GearLink
Hot RacingAON311M01Aluminum Center Sway Bar MountsLink
Hot RacingAON24M02Aluminum Steering Servo MountLink
Hot RacingAON08FR01Aluminum Front Lower Rear Suspension Arm MountLink
Hot RacingAON08FU01Aluminum Upper Front Suspension Arm MountLink
Hot RacingAON10M01Aluminum 17mm Friction Dirt Shield Wheel NutsLink
Hot RacingAON21N02Aluminum Delrin Cap Hub Nut with O-Ring RedLink
M2C RacingM2C 3065Ackerman bar/Steering rackLink
M2C RacingM2C 3080Shock tower stand off kitLink
HobbyWing38010405EZRUN MAX8 G2 COMBOLink
PPS RCn/aGrublock Motor MountLink
PPS RCn/aSWITCHFORK Switch Mount for Hobbywing ESC'sLink
Robinson RacingRRP121717 Tooth Hardened Steel Pinion GearLink
Pro-LinePRO9067411/8 Badlands MX M2 Front/Rear Buggy Tires Mounted 17mm BlackLink
-= Electronics =-
Hobbywing 4278S G2 2250KV Sensored Motor
Hobbywing Max8 G2 ESC
Flysky INr4-GYB Receiver (used with Noble NB4)
-= Differentials =-
Front - 50k
Center - 300k
Rear - 30k
-= Gears =-
17T pinion
50T spur gear
Currently, the car is in pieces. During my annual maintenance, I do a complete teardown, clean everything, check/clean/replace bearings, and perform any upgrades I haven't got around to yet.
Box-o-Typhon
Diff Parts and Bearings. Theres more parts here than whats required just for the Typhon, I'm working on some other cars too.
Box-o-Typhon
You gonna rebuild it with the HW?
Nice! Still planning for primarily 4S? What size pinion are you thinking?
4s for now, I'm excited to see what the new motor will do for me compared to the stock motor. This is my first time changing the ESC & motor away from stock.
I had a 25T pinion in there already, I think I'm going to stick with it for now also for comparison purposes and then see if I want to go up or down after a couple runs.
You may want to keep a close eye on temps. The stock Spektrum 6S motors test around 1900kv actual, where I’d guess that HW 2250kv rating is more accurate. 4S geared for 70mph may heat up quickly.
I love how the only ARRMA parts listed aren't even for a Typhon 🤣
Yes - I've "truggified" my Typhon so that I can run monster truck tires if I choose to do so, it also widens the car a small bit which I like. I haven't run MT tires in over a year, but I plan on keeping this configuration as I'm also in the process of building an XL Typhon which will be on-road only. The car featured in this thread will be dedicated to off-road adventures.
I've updated my first post to add some clarification about the parts list.
Oh I know, my Typhon has all the same Kraton parts and MX28s. It's just funny seeing a whole list for a Typhon that's either Kraton, or aftermarket. There is NOTHING on there that came from the factory lol
Thx for taking the time to create and update the table. I am definitely going to copy some of your ideas. ;)
Winter rebuild and maintenance is now complete! I still need to check my camber and toe, which I'll do before it's first run. As the ESC and motor are also new, I need to play with the ESC settings to figure out which configuration I prefer.
I used to have a T-Bone bumper on the front, but I've decided to remove that for the time being. Not sure if I'll ever put it back on or install some other bumper, we'll see in time. I've replaced the stock velcro straps with a single Kevlar reinforced strap. I've removed the front vertical sliding part of the battery tray as I now need to put my battery in backwards due to the short leads on the ESC. Maybe at some point I'll play with different ESC positioning. The issue now is that I don't have a good way to strap down the battery and ESC wires, so they are going to flop around - I need to figure out a solution to this.
Here are some pics:
Nice! Those new HW motors look great.
Could you loop the battery wire under the velcro before connecting to the ESC? It looks like that may help keep it taut.
How do you like that motor mount? PPS?
Looks great man, nice rig! Also, the table you made for parts and links in the build thread is fantastic, what a nice and concise approach.
Waiting to hear how you like that HW G2 setup, I’ve been really curious about those since they dropped. Nice that the HW’s are finally sensored.
Its really nice! Setting gear mesh is so much better now. Just turn a screw to set your mesh, the screw holds it in place while you lock down the motor mount screws. No longer does the motor mount move while tightening the motor mount screws, moving that mesh you just spent 20 minutes trying to get perfect.
