jondilly1974
Speed running apprentice, motor Slayer 🤘
- Toledo, OH
- Granite
- Infraction
- Kraton 6s
- Kraton EXB
- Senton 3s
- Typhon 6s
- Typhon 3s
You can grab a MM2 that is unlocked and unlimited...Amperage values are certainly imaginary in car ESCs. I have seen some data in Castle Data logs that indicates their Amperage numbers are completely bogus. I don't believe people are seeing the sort of power they are lead to believe by those logs.
Example from an 8s setup I had. 8615 watts / 746 = 11.5 hp (if you believe the data)
For the LiPos output it certainly depends on the brand/model used. The Turnigy Graphene's have been tested (with good test equip.) up around the 300 amps range for short durations.
The speed run community has repeatedly found that Hobby wing and their RTR versions like the BLX 185 hit amperage cut off (programmed protection).
Castle Mamba series ESCs do this also, but at a higher amperage number than HW does.
If we have amperage unlocked ESCs then everyone would complain about ESC failures all the time, and the manufacturers would be swamped with warranty work.
-Liberty
http://www.castlecreations.com/en/exclusive-offers/monster-v2-retro-1-24sw-sold-as-is-010-0108-98
