thegunsmith
- BigRock 4x4
Selling my big rock crew cab 3s with lots of extra parts and (2) 3s 5200mah 50c continuous batteries. The truck and batteries are like new both were purchased on March 5th. The truck only has 19 full runs on it(19 fully charged batteries) and yes I did keep track. The batteries are also like new, battery 1 has 9 charge/ discharge cycles and battery 2 has 10 charge/discharge cycles. I always balanced charged them and if they were going to sit for longer than 24 hours I storage charged them. Both the truck and batteries are like new and in perfect working condition. The rear differential on the BRCC was replaced with a whole new assembly and input gear on 4/13 and the spur gear was replaced at the same time. I replaced the bushings in the steering bellcrank with sealed bearings from Jimsbearings and I also changed all bearings in the rear differential to sealed bearings. Everything that you see in the pictures will be included, I also have a charger I can include for more $$ but it’s an older charger and takes about an hour to balance charge the batteries I have.
What will be included :
$340 plus buyer pays shipping
The truck was never abused or run through water I always made sure to avoid any amount of water. I always took it very easy on the truck, no big jumps or anything like that. Well taken care of always cleaned after each run and taken apart/inspected for damage. Please contact me if you have any questions.
- Complete BRCC in perfect working condition
- Tactic transmitter (comes stock with BRCC)
- (2) Powerhobby 5200mah 11.1v 3S lipo batteries, 50c continuous
- Extra parts for the center driveshaft including spring(see pics)
- (1) front suspension arm
- Extra loose bearings(4 new 3 used)
- Half of the slipper hub and new slipper plate(unused)
- Extra screws
- Differential( one tooth has a small chip on it but I’m sure it’s be fine if you needed a replacement and couldn’t get one at the LHS
- Losi shock oil
- 17 of jims bearings for the rest of the car that I haven’t changed the bearings on yet
- One bearing from Jim for the motor (there are already jimsbearings in the motor)
- AR310872 - Diff case set 37t main gear
- AR310880 - Slipper plate and hub set
- AR610001 - Ball bearing
- TLR5282 - 10k diff fluid
- AR310873 - HD input gear
- AR310875 - Diff gasket (2)
