You need to explain what the issue is. I've had tons of issues with my Arrma diffs but there are many different issues and therefore many different solutions. If the issue is inside your diff, you should shim them. If you're eating input and ring gears you may also need to shim the outdrive. I also replaced the plastic bulkhead with the Hot racing metal one and that made a huge difference on saving input/ring gears because it doesn't flex like the plastic one does.Any thoughts on best replacement rear differential
Oh first post hope I did this right and my question isn’t to lame!
Sorry about that, thanks everyone for the help lot of great information. Should have told you all that the dog bone has popped out twice now. Just need to know what to replace or what to do. Thanks everyoneThere's really no need to replace the rear diff on an RTR: it's not likely to experience a failure. You can tune it to your liking by using different weights of diff fluid. Here's a chart to guide you:
https://www.arrmaforum.com/threads/differential-oil-weight-tips.1727/
