- SE MICHIGAN
- Granite
- Infraction
- Outcast 4s
- Outcast 6s
- Outcast 8s
- Typhon 3s
- Typhon 6s
Hey guys, just picked up an Outcast, started life as a rtr, for all intents and purposes its an EXB now with the exception of the shocks. I've done quite a bit of reading, but I'm hoping some of you guys that do heavy bashing and big air can chime in. My question is this: what's the best bang for the buck when it comes to the shocks? Are the rtr shocks with the 5mm shafts ok if you drill out the pistons and run M2C rod ends? Should I grab a set of the EXB shocks with the 6mm shafts and throw a set of M2C rod ends on those? Order the 7mm ISB kit for the rtr shocks? I plan on beating the snot out of this thing like the rest of the rigs and I'd like to skip the common shock failures as much as possible... thanks in advance for any input!!
