- Maryland
- Infraction
- Limitless
- Mojave EXB
- Senton 3s
- Talion
- Typhon 3s
- Vendetta
3s Vendetta Speed Run Challenge
(Leaderboard here)
We are going to keep the overall rules of this challenge as open as possible that way guys can get their cars setup how they want. We will have a column for stock body vs not.
Rules:
1: Open to any body to be used
2: Open to any of the Arrma plastic chassis’s to be used with vendetta arms
3: Battery setup can be single or parallel setup.
4: GPS rules for current standard accepted runs:
- zero out prior to run
-show car moving and picking up gps after return trip of car prior to gps reading
-no crashes
-return trip preferred ( but acceptable if car is in road and you have to walk/drive to the car because of traffic or not being able to see the car. also during this time follow prior rule of showing the car moving and picking up gps before reading.)
5: after the run verify voltage of the battery in the car using a battery tester or multimeter,
6: no edited videos with time cuts, if needed you can use fast forward options in a video editor, but it should be one continuous shot.
7: any tires can be used
8: any ESC and motor can be used
9: Most important … HAVE FUN and Help Motivate each other to go faster!!!
PLEASE POST VIDEO LINK IN THIS THREAD SO THAT WE CAN KEEP TRACK OF NEW PASSES
Currently we are leaving an open time frame for this Challenge and at some point there will be an end date implemented once we finalize some prizes for top spots.
(Leaderboard here)
Rules:
-no crashes
