As others have said, Max10 G2 140 Amp and 3665 motor at either 3200kv or 2400kv are the way to go. 2400 for 4s or 3200 for 3s. If you don't want to shell out the extra dollars for Max10, Amain has the 10BL120 G2 combo with 3660 for 76.50 or something with coupon code NCF24 or NCF24A right now which would be great.Can I put a Hobbywing Combo Max10 G2 80A Esc 3652Sd 5400Kv Blk G3 Motor in my vorteks boost?
Which is what kind, brand do u have a linkTechnically yea you could. But I'd go with a torquier, lower KV motor that should also run cooler.
