- Notorious
Should have came with an assortment of horns. Can you use one of the thin disc ones?The issue is that, with it on the front of the mounts, its too close to the steering arm. This is the servo im trying to use: View attachment 52696
and the problem is that is has to fit inside this box:
but from the mounting tabs to the top of the servo is too long, so it jams the steering linkage, and there is no way to move the servo back in the box.
Another issue i just happened to notice is with the servo horn. The Spectrum is a 23T, and very thin, whereas the one on the DS servo is a 25T, and about twice as thick as the one on the Spectrum, so, now i get to find a short, thin, 15MM eye to eye, 25T servo horn.
