ATOMIC cap packs SAVE 15% NOW!
I build my own Cap packs.
I think Atomic should have used 50 Volt caps to begin with and a higher Uf and especially for 8s applications.
Electronic Engineers would agree that you always try and Double the CAP voltage for its intended voltage use. The caps will run cooler. Caps normally run very hot in general. Heat is what makes the caps Pop. Caps don't last forever. They wear out. Some sooner than others. Atomic in their ad, using 35v caps is just cutting corners IMHO.
Looks to be made very well.
If I may make one suggestion concerning the video/audio - when you're speaking, drop the volume of the music by at least 5-6dB. It's really difficult to understand what you're saying...and my ears work. That's going to elicit a lot of "huh?" from people who have difficulty underestanding others in a crowded restaurant and the such like.
