So the rear diff blew out on my big rock. Both the input and the output gears. I don't feel like spending 50 for the hot racing metal ones but I want to upgrade it. Any suggestions?
Sorry to hear that.... Jenny's is the cheapest way to go.
How do you have that setup...? Belted tires, heavy diff fluid...also check the diff shim you need a shim on the crown gear side...could need two but check the mesh between the input and the crown.
There should be one on there now. It would be the same size and part number.Yea I probly do need to put some shims in it. What size should I get?
