- Granite
- Kraton 6s
hello new to the forums!
so i just purchased an Arrma Granite 4x4 brushed version and am having an issue.
so i bought the truck and got it home, charged up the batteries and tested the trims, and made sure the esc plugs were correct positions for NiMh and reverse lockout was not activated. (everything was good from factory). turned it off and went through all the screws that i could find on the outside making sure everything was good and tight. for the most part everything was. then got it packed up in the car and went to run it.
ran great for the first part, really surprised handles really well, doesn't feel top heavy good responses from the controller, (also surprised about the strength of the stock servo) near the end of the run right when you could tell that the battery was starting to get low, the truck cuts out.
go to switch on and off the esc runs again for a few seconds then does it again. check temperatures of the electronics, battery was warm, motor was reasonable, feel the esc, its a bit warm not really alarmingly hot so pack it up and bring it back home. out of the trouble shooting all i could compare is a thermal shut down.
then the weather got cold so put it up for a week or 2 and was able to run it again today. ran fine for most of the time then did it again right near the end. this time the esc and motor were good temps but the battery was quite warm.
any ideas what could be going on? battery seems to last a decent amount of time, esc seems to work properly, radio seems fine.
( both runs were in just a parking lot not necessarily speed runs or anything.)
Thanks!
Thanks!
