parcou
Hospitality Award
Rig of the Month Winner
- Memphis, TN
- BigRock
- Felony
- Fireteam
- Granite
- Infraction
- Kraton EXB
- Talion EXB
- Typhon TLR
- Vorteks
Fam, Need a little help
I know the correct way to refill shocks with a bleeder hole like the Typhon 6S shocks. I am lost on the Losi DB Pro shocks that have no bleeder hole but does have a bladder inside, a very small bladder.
What I have been doing and videos vary or limited on ones with no bleeder hole:
What I have is very different from the Typhon shocks. Typhon I can push the piston in but it might come out a little but will stay close to full compression. With the same steps above with the Losi (no bleeder hole), the piston will push back out and slowly move to almost fully extended. On the steps above, I cannot push it fully compressed it is like the bladder is pushing it away or back out.
This could be correct for this shock. My question is am I doing this right or wrong because YouTube has just confused the hell out of me?
Thx
@razorrc @SrC
- With an empty cleaned shock, I have the piston full extended
- I fill with shock oil
- I then pump that slowly up/down and twist the piston to release air
- With the piston back at full extension, I leave it on my shock stand
- I may top off the oil to the top if there is more needed to where it is at the top but not spilling over
- Wait as long as it takes for all air bubbles to leave
- >>>> here is where I am lost <<<<<
- I put the cap on and slowly begin to close it but leave a 1-2mm gap so not fully closed
- I then slowly begin to compress the piston until it is touching the shock body
- I fully close the cap while holding the piston in full compressed position
- Clean off the little oil that came out
Thx
@razorrc @SrC
