Help with hobby wing.
Finchy
Alberta canada
  2. Outcast 6s
  3. Talion
  4. Typhon 6s
I have ez run max 8g2 and 4268 g2 sensored motor. It’s in my tlr typhon. It periodically hesitates/cuts out when approaching my ramp at home. Can’t figure out why. It cut out but instantly works again it’s just a split second when biting the quarter pipe. Can’t figure out why
Could be a bad sensor. Unplug the motor sensor wire and see if that helps.
Could also be an issue with the receiver / transmitter.
Ok I will give that a whirl. It does do it on Flat ground at times. But is so quick it’s almost like a glitch. Almost like a dead spot. I have only 4, 4s packs in the esc and motor also the car
Same issue with my Max6 G2 4990 combo. Also when approaching ramps. yea its nothing like a brownout. recovers insanely quick
I saw a video on youtube about this. Looked back in my history, but couldn't find it. I believe it was a software update that was needed.
I think the Max5 G2 is the only one so far to receive a firmware update addressing the issue, or at least a similar issue.
