So the 4s outcast and kratons have a lot of movement in the steering linkages and tie rod ends. When you move it back and forth you can see A lot of it comes from the pillow balls moving inside of the tie rod ends.
Does the hr kit actually have slightly bigger balls and does it help tighten it up or is it just more durable. I’ve searched and there is videos of the installation etc but I don’t see anyone compare them to each other as far as whether they have tighter clearances inside the rod ends. Thanks
EDIT. SEE END FOR INSTALLATION RESULTS.
