Getting out of RC to focus on other ventures. Selling as a package so not in a rush. Asking $675 shipped 48. No electronics...I figured whoever grabs this roller would have some laying around anyways. Not parting out. If you are near the CSRA you can pick it up for a discount.
Listing everything to the best of my memory:
Infraction body complete (front windshield section and rear window sections were cut for cooling and reaching the power button easier)
Limitless body with nose (partially cut for cooling)
Hot Racing front/rear chassis braces
Hot Racing steering set
Hot Racing 25T servo horn and aluminum linkage
Hot Racing front/rear T2T brace mounts
Hot Racing Center Diff top section
PPS Center Diff Carrier
PPS Adjustable Motor Mount with small and large motor mount plate
50T Spur installed
Arrma Aluminum Diff Cups f/c/r with 60/500/30 diff weights
Hot Racing bulkheads, bulkhead covers, sway bar covers
All aluminum arrma shocks (shock top, bottom, collar)
Hot Racing wheel hubs front/rear
Arrma CVDs front/rear
Fast Eddy Bearings all around
3D printed TPU slugs in center diff for no slop in dogbones
27T pinion
Spool shaft spare part
Spool spacer set spare part
39T spool gear spare part x2
46T spur gear
37T spool gear set
Battery tray set pair
ESC/RX/Servo trays with covers x2
Front bumper brace x2
Infraction foam brace spare set
Infraction/Limitless side strips spare set
Limitless front splitter spare
Infraction front splitter spare
Front bumper spare
Infraction body mount set spare
Rear tower brace spare set
Spare miscellaneous parts
Stock Limitless hoons installed
GRP S7 set NIP never used
Amazon road tires 2 sets. 1 set used with tread left. 1 set NIP requires glue.
Infraction white hoons with rims (rims can be salvaged)
Felony rear white hoons. 1 pair NIP. 1 pair no packaging. Both pairs never used
It is dusty/dirty in the pics from having sat since the last time it was used (months ago). Never used in wet conditions only dry/dusty. Never cleaned with any wet solutions only compressed air and shop-vac. Last run it tracked straight and uneventful.
More pictures
50T Spur installed
27T pinion
46T spur gear
37T spool gear set
Front bumper spare
More pictures
