Hookmeuprc
- Infraction
- Thread starter
- #21
Hookmeuprc WHAT KIND Of motor are you running and is that a 6s ripper killer cap pak?
Looks good!!
I will be installing the Castle Creations MAMBA XLX2, 8S, 33.6V ESC, 20A PEAK BEC & an 8s RIPPLE KILLER cat pack set up in my v2 Infraction!
Which should put me np in the 120mph club.
The motor is a LMT (Lehner Motoren Technik) 2250/7 HiAmp car version.. ??
No it’s not a 6s Ripple Killer pack, it’s an 8s version, no point running a 6s on an 8s rig.. ?
Depends, what motor will you put in but should be at least 120mph! ??
With the right gearing, you could be in the 140+ range ??
You will need a Limitless spool the get gearing in that range. I would also recommend a @PPS-RC motor mount and diff setup with the V2 brake mount attachment. This will allow for perfect mesh with a wider range of gearing.
I bought a spool and pinions up to 40T for a speed run if I can ever find somewhere to try it ???
Those PPS motor mounts look pretty good? I have an EM Performance LE motor mount setup with Racing Innovations CF top plate and spacers for the motor mount.. Most of my CF parts were from Racing Innovations.. I like the mount, Either can or almost can do 1:1 gearing with the spool ???
