Thanks for the info.Look to CNHL on AMZ. Might find a deal. 5000-6000mah is a good choice. If you are good with soldering, you have more choices/ better selection. Can possibly get a good deal with a lipo that has any type of connector. Just solder on your own. What I do. Never use Lipo connector adapters on you rig.
There are many choices. Just make sure you know the dimensions of your 4x4 lipo tray for a proper fit when shopping.
Should I use one battery or two?Look to CNHL on AMZ. Might find a deal. 5000-6000mah is a good choice. If you are good with soldering, you have more choices/ better selection. Can possibly get a good deal with a lipo that has any type of connector. Just solder on your own. What I do. Never use Lipo connector adapters on you rig.
Welcome to AF.
Thanks for the good info. It's good to know that.Use one lipo. Best.
Adapters are ok for connecting a Lipo to your charger. That is all. On the Rig, adapters become bottlenecks. Less efficient amp draw. Can get hot. A liability. It is just not correct from an electrical standpoint. You increase resistance across the Voltage circuit. Increasing potential failure points.
Using an adapter between the lipo and ESC is the Lazy mans way of doing it. Just run matching connectors for the ESC and Lipo. The rule.
Do it right. Or just wait till you fry your ESC and lipo. Your call.
Getting away with doing it so far, is just tempting fate.
You are not alone. Many get burned first before they realize this and change their ways in regards.
Been there.
Ther are limited exceptions to this and paying special attention to the adapters and their temps is paramount. Like when running paralell leads with Road speed runners, etc. High end expert level rigs.
