Fugitivelama
So I had a fairly small crash , stock gearing and not really running too fast. Since the crash My Steering is not perfect. If I turn all the way right then center it , it works fine. However when I turn full left and then center it , it does not return to dead center without some help from me steering it. I have tested this both on pavement as well as propped up so the tires are free and clear of all resistance. It's a pretty noticeable amount and the car will steer that direction heavily if I do not adjust after coming out of a left hand turn. Once I do adjust it the car will drive straight as can be, even at full speed.
The Bumper and splitter were damaged and I have ordered new ones. The Suspension mount in the front is split at the retaining screw. The chassis is also ever so slightly bent. I have ordered all of those parts as well. I cant see anything bent or messed up on the steering or tires. So my question is , what am I missing? Could the Servo be stripped internally?
Any suggestions for an upgraded servo regardless?
I couldn't find any videos for how to change the chassis , How difficult is it?
