srt8hellcat864
Hello and Welcome!View attachment 332041This is my infraction dragbuild.I will be running a castle creation 1721,and ds5 pro controller.
Okay thanks man. I was thinking I may need a faster and stronger servo for the Telemetry to work right on hard accelerations.Hello and Welcome!
Infraction stock servo can be weak, but mine did not fail until a year later. Some sooner. I never had a real issue with the stock since I was hooning and drifting only. You only needed a little steering when you power slide, so stock worked fine until it died.
If you are speed-running, you might consider upgrading if you find your servo is not holding straight, which will be necessary. Drifting the 30-35kg Amazon servos has done just fine.
It depends on what you want to do and if your current is performing as it should.
Yes, most do replace the Infraction 6S servo.
