Ok, so I've done some forum searching and the only things that have come up are about stones, or broken/fried (insert part). None of which started out with the issues I'm seeing. Hopefully you guys can help a noob out.
I had this happen on my BRCC once and after a power cycle it never happened again, but I just bagged a Senton and on our first run with it yesterday on a short grass soccer field, it happened...…a LOT. I'd already set the end points, and calibrated the ESC prior to our quick run, and the Senton has an upgraded servo/saver. Here's the play-by-play of what I experienced yesterday-
-While driving at any speed the steering sticks to varying degrees in one direction, or another usually based on which direction the truck was turned.
-Turn in the opposite direction under power and steering changes and gets stuck to varying degrees in that direction.
-I took the body off and checked for anything that may have been stuck in the steering assembly, but found the whole area clear of anything (it was a short grass field).
-I gently tried to move the steering manually and nothing budged and I stopped.
-I turned off the power and the steering freed up, and when I turned power back on the steering would either return to center, or return to where it was stuck last. It was a coin flip to which would happen.
I'm not sure, but I think it's important to note that at no time did I lose steering control, or steering at all. It would just get stuck in one direction, or another with no real consistency as to how far in that direction it stuck. I appreciate the help with this. I really want to understand why this happens, any troubleshooting tip/steps, and what the fixes are for future reference. Thanks in advance.
