NewKratonuser0311
- Points
- 103
- Infraction
- Limitless
- Kraton 8S
- Typhon 6s
I’m currently using stock 39t spool and 30t pinion. It seems that the pinion gear and 39t spool gear aren’t meshing well. Seems that the motors needs to slide in just a hair more but motor mount is pretty much all the way in. Am I missing something or do I need a different motor mount or the 56 series sliding plate. I’m going w a tp 4070cm 2200kv motor. Also the shaft is a lil short the pinion gear on the motor is almost on the end of the motor shaft. Can that be a potential problem?
