Grom Tire options
Goldendrakester
MN, Rochester
  1. Granite Grom
  2. Kraton EXB
  3. Talion EXB
Are there any alternate tire options? Preferably 10-15mm larger and under $40-$50.
So far I've put some lightning epx drift tires and those are fun to drift it with.
Maybe the tires from the Lc Racing EMB-MT or EMB-T. I'm not sure what the outer diameter is off the top of my head and I won't be home for a few hours from the looks of things. But I can get them for you then.
I think 90-100 mm tires would fit perfectly, as I have some sitting around. They are off a Walmart car though so I don't want to use them, but when I set them up next to it they looked to be about right.
Oh poop, I completely forgot about this. Reply to this thread at about like 3pm mountain time so I don't forget again.
These are the truggy tires https://casterracingmi.com/index.ph...uct_id=2274&sort=p.price&order=DESC&limit=100
And these are the Mt
https://casterracingmi.com/index.ph...uct_id=1757&sort=p.price&order=DESC&limit=100
has anyone looked into this?
What are the dimensions of the stock tires?
The LC Racing EMB-MT tires are 85mm in diameter. EMB-T tires are 86mm.
As a side note Jconcepts Goosebumps for the Mini E-Revo are 87mm.
Proline 2.2 Trenchers for the Mini E-Revo are 92mm.
This is what they look like on the Ecx 1/18 Ruckus which is the same size as the Grom.
I can put the Goosebumps or LC Racing EMB-MT tires on my Ruckus if you want to get an idea of what they would look like on the Grom.
I can check when I get home today
I can check later today but I believe they are around 80-90
The EMB-T uses 2wd 1/10 buggy wheels if I’m not mistaking.
I’d say for looks, redcat volcano 16 tires. IMO 1/16 tires can’t look much better
82mm tall and 50mm wide needed the body heated and tucked(norcal) for full turn radius. Offset(backspacing) is also important for clearance.
