Thanks!!!! Looks like the metal ones on Amazon have terrible reviews? The closest hobby shop I have is an hour away here in alaska so kinda a hassle to get to.thats a turn buckle, your local hobby shop should have them, or get an upgraded set off amazon
Ooohh I like those but they're out of stock... darn. Should I just get these until those are back in stock or buy the Amazon ones with bad reviews lol.Go ahead and get the BLX version while you're at it. Direct swap and a bit stronger. Keep the remaining Mega ones you take off for emergency spares.
https://jennysrc.com/products/arrma...-rear-granite-ar102696?variant=19223746773046
Does the whole set fit ?After bending numerous turnbuckles on my cars with the longer big rock/typhon arms I switched over to Traxxas rustler turnbuckles. They are stronger (I haven’t bent one since switching early this year) and also have metal balls (Arrma turnbuckles have composite balls). They fit a bit loose at the shock tower mounts but a small washer is all it takes to tighten up the fit. They are in stock also.
Yup, they adjust quite a bit. On my parts bin Typhon I just built I used a whole set of rustler turnbuckles. I put one washer where they attach at the bulkheads since it’s a bit loose. At the other end I just tighten up a bit more till snug. If I remember right the steering rods are pretty spot on but I may have used a washer.Does the whole set fit ?
I got the rears and I’m liking them so far.
