8s infraction stuck at 85 mph
Ccajigas07
Infraction, Talion
hey guys need help my infraction is stuck at 85mph when it should be way up there, im guessing is my gearing but i want to know what gearing will get me to surpass 100 mph
Current setup is
Tp power 4070 8s 2250kv
Mamba xlx
Killmode 6 pack 13200uf cap pack
Dual spektrum smart batteries 4s 100c
Limitless spool 42t spur
29t pinions
Bsr red foam mount tires
Mr.Duke
~ Gray Matter Minimalist ~
Staff member
NC
Kraton 6s, Notorious, Outcast 6s, Talion, Typhon 6s
Current setup is
Mamba xlx
29t pinions
Limitless “42T” spur? Is that a custom 8mm spur gear from Saga?
Ccajigas07
Infraction, Talion
Basically the center spool from a limitless with a 42t spur it eliminates having a center differential
Mr.Duke
Staff member
NC
I was asking if it was a custom size spur because the limitless comes with a 34t and not a 42t
A 2250kv with 29/42 should land you in the 140’s whereas a 29/34 will be way over geared
jondilly1974
Speed running apprentice, 3D printing fool
Toledo, OH
Granite, Kraton 4s, Typhon 6s, Typhon 3s
Off rip, I’d say those lipos are junk. Get some Graphene Panther, CNHL G+, or SMC Extremes.
Ccajigas07
Infraction, Talion
So saying i get different batteries what gearing to i get
Turbobrick
Infraction, Limitless, Notorious
Have you checked the logs I believe the xlx is set to 200amp out the box
Create account
Log in
