CentriBoosted
Anyone done this yet? I remember a few years back rc8b3 lower arms worked as did mbx7 arms. Any photos floating around that can show it done?
Should work with TLr Typhon blocks then too. What hinge pins did you use, ARB mounts, etc.?Yes. I am running MBX7 front arms, upper and lower. The lower arm is lighter than the Typhon. The upper arm is about 0.4 grams heavier.
On the rear I am running MBX7 hubs with MBX6 arms. The MBX6 arms are longer and are needed with the Typhons narrow C and D blocks.
