On-Road Arrma Rear Control Arms; Extremely Flexible
httuner
  1. Limitless
  3. Senton Mega
  4. Typhon TLR
I've been noticing that the rear control arms on the Limitless is extremely flexible; I've been trying to see if there are any other alternatives out there to solve the issue besides aluminum arms.
Anyone notice this too? Just with slight pressure I can twist the arms.
You could put CF plates on top and bottom. Fill the void with epoxy and then screw the two together.
I'm going to try the Mugen MBX8R rear lower control arms and go from there. Only issue is I am unsure if they will fit with the Arrma outer hubs; I suppose its worth a shot, but I've held off since I'm still trying to get some Mugen folks to help give me some dimensions.
How much flexible???
Too Flexible; with the stiffer perfect pass springs; pushing on the arms definitely can see it bend more. Given some flex will help with traction but maybe I'm just being anal about it. I want to dial in the suspension perfect.
