I'm in the same boat not sure what to get, the one servo that someone else recommended to me is out of stock and might be a bit overkill.Anyone replace their servo in their 3S Typhon? I can't seem to find a good replacement recommendation. Thanks
6221MG is on the slow side, imho I would try to stay below .14 seconds.ADS-15 or JX PDI-6221MG are a solid choice.
Has anyone replaced one and knows that it fits?
I just measured my stock servo and I got 40mm.Maybe Im measuring something wrong
I've got the DS3218 in a couple rides and seems to work well enough.I put the amazon specials, the $17 20kg waterproof servo in both my bigrock 4x4 n my typhon 4x4
Was it easy to do? Any tips for doing it?I put the amazon specials, the $17 20kg waterproof servo in both my bigrock 4x4 n my typhon 4x4
Did you reuse the servo saver? Did you remove the entire electronics module to put it in?I put the amazon specials, the $17 20kg waterproof servo in both my bigrock 4x4 n my typhon 4x4
Is your stuff? Or looking for better performance?Anyone replace their servo in their 3S Typhon? I can't seem to find a good replacement recommendation. Thanks
