Hi,
Pretty much decided on a Typhon 6S (unless a new Talion is released pretty sharpish). I’m now onto sourcing batteries and charger. I didn’t quite realise it was going to be quite so complicated.
I scared myself by reading about lipo fires so I thought I’d go with hard case batteries for durability and the Spektrum smart batteries and charger as even though they’re a bit more expensive, as a newbie it’s less things I have to worry / learn about. I like the idea that the charger will look after me a bit. I’ll also get a Bat Case etc.
Arrma recommends 100C 5000mah for the Typhon but the Spektrum 6S 100C 5000mah hard case won’t fit. Neither will the soft case version. Neither will 2 x 3S hard case versions. The only option seems to be 2 x 3S soft cases but the second gen versions shown on their site don’t seem to be out yet and I can’t find first gen softcases anywhere. Did the first gens even exist?
So I thought I’d take a look on Hobby King and filtered by UK (I’m in the UK), size, spec etc and there’s none that fit those criteria.
I’ve had a look around on some other sites and I’m struggling a bit at the minute.
Does anyone use the Spektrum batteries in their 6S Typhon?
Are there any hard case options that fit in the Typhon?
Do I need to drop down from the recommended spec to make them fit?
Any other options avliable in the UK or advice?
As someone new to this, the amount of confusing spec and information is pretty overwhelming.
Thanks.
Thanks.
