Best shock oils
Rhett
Starvin Delmarvin
Berlin, Maryland
  1. BigRock
  3. Nero
Well I ordered my new Armma Notorious, I'm super stoked! Now on both my kraton and notorious. What weight oil should I use also on the kraton I just put some killer billet big bore shocks.
I used 30w on these bad boys only 1 hole in the shock baffle but they work well
I should go through the additional parts that came with my outcast... wonder if there are shock pistons in their with smaller holes. Starting at 80wt doesn't give you much room for adjusting. Would rather have pistons that react similarly with 50wt so I could increase it a bit without finding some exotic oil or blending in 2000wt diff oil, which is what I did.
