samintrepid
- BigRock 4x4
Thank you my friend, I have reput the original wheel for top speed because he ballon less than badland mx-38. I have start a build off of a new Big Rock Crew Cab 3s Blx with all my spare part I just buy a new chassis and bulkhead all the other part are in stocksamintrepid: Your BRCC looks Awesome! Did you go back to the original Wheels & Tires or do you have 2 BRCC's ?
I know you had Hot Racing Extensions & 2.8 Pro-Line Badlands on a BRCC at one time!
Anyway love the new look! : )
You don't have too many option with the 14mm wheel, the only offset with 14mm wheel are the GPM 9mm thick hub. The factory 14mm hex have 6mm thick and GPM 9mm thick give you 3mm extension on each side and the truck become much more stable you have to try it really good.I think the BRCC is fast enough for me, I would like Bigger Tires & a wider stance because at full throttle if you turn just a little it will roll
like crazy! I already have the 12mm wheel hubs but haven't bought 14mm x 17mm extensions or 2.8 tires yet ! I may just stick with a 14mm
wheel and buy the 3S Granite Dboots wheels & tires if I could find a 14mm x 14mm extension with a 15mm or less offset?
Wow perfect if you put the GPM hex with the Duratrax wheel that will give you good extensionI have GPM's 9mm hub saved in my favorites and now towerhobbies has plenty of 14mm Wheels & tires that are Duratrax and descent sets.
https://www.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=&FVSEARCH=duratrax+14mm
I have buy the Duratrax Deep Wood tire for my trx-4 the foam are little soft but the rubber are high qualityI think that's exactly what I'll do for first new set then buy the 12mm x 17mm Extensions and 2.8 Badlands if I'm not happy with the Duratrax
Set but most reviews say there a bit soft but really good traction for light bashing & that's all I'm good at right now anyway! hahaha! : )
I purchased the GPM 9mm hex as well, but when i went to tighten my tire, i did not have a enough threads the tighten doen the tire. how do I get these to work. picks or video would be greatYou don't have too many option with the 14mm wheel, the only offset with 14mm wheel are the GPM 9mm thick hub. The factory 14mm hex have 6mm thick and GPM 9mm thick give you 3mm extension on each side and the truck become much more stable you have to try it really good.
Hello my friend, GPM include a thin stainless nut and when it screw it happen flush, if you put the factory nut you don't have enough thread. If your not able I will make a small video for youI purchased the GPM 9mm hex as well, but when i went to tighten my tire, i did not have a enough threads the tighten doen the tire. how do I get these to work. picks or video would be great
I did not receive stainless nuts with my 14mm x 9mm hex from gpm.Hello my friend, GPM include a thin stainless nut and when it screw it happen flush, if you put the factory nut you don't have enough thread. If your not able I will make a small video for you
