you will have to cut a piece of the side guard off to fit a motor longer than 92mm iirc. You could easily fit a max 6 5687 1100kv combo in there if you wanted to. Not with stock motor mount though.
What motor Mount can I find to fit the max 6you will have to cut a piece of the side guard off to fit a motor longer than 92mm iirc. You could easily fit a max 6 5687 1100kv combo in there if you wanted to. Not with stock motor mount though.
