Notorious Notorious 6s max6 motor
dannymaka
Hi guys, just about to order a max6 1650Kv motor combo for my 6s notorious v5
Could anyone tell me what size pinion would be the best for this motor with the stock centre diff?
Cheers in advance
Cheers in advance
I run a 20T pinion on my Kraton 6s with a Castle MMX 8s with 1717 1650kv motor. I started with an 18T pinion, but the 20T gave me better performance without a significant increase in motor temps. I do run the Arrma aluminum and steel center diff case to better dissipate heat, but the spur is stock.
I use 19, 20 and 21 with my Outcast. Normally I use a 19, it has enough wheel speed for triple backflips at the skatepark and enough top end for most of the more open places I run it.
I found 21 to be the sweet spot in my Talion when I put the combo in that for a bit
