So I’m putting the MMX6S with a 1800kv motor in my sons kraton and I can’t get it to go fast? It drives fine but only goes 10-15mph. With a 4S 100C battery it should go way faster!
Did you calibrate the throttle?So I’m putting the MMX6S with a 1800kv motor in my sons kraton and I can’t get it to go fast? It drives fine but only goes 10-15mph. With a 4S 100C battery it should go way faster!
Good point ! Always make sure to calibrate throttle. And make sure motor direction is right. Good one RobDid you calibrate the throttle?
Also, does it go faster in reverse then forward?
No and yes.Did you calibrate the throttle?
You have to do it for Radiolink stuff too.To my understanding you only had to reverse the channel if using Futaba radio gear.!!
Then use a castle link or b-link an reverse the motor direction like @Forbes said and recalibrate.I did not.
No and yes.
Good to know that.You have to do it for Radiolink stuff too.
