thanks, is there anything else I could use instead of simple green, seems very expensive in the uk.
Spray it with WD-40 and let soak..
It'll be oily but will do the same in loosening dirt and grime off the
Soaked wd40 and scrubbed, dremel/ polish. Sorted. Wont last long, but it's clear of grub.Any common organic solvent mixture intended for parts cleaning (naphtha, brake cleaner etc.) and a stiff plastic bristle brush and scraper will get them about as clean as you can without damage or diminishing returns on effort. Some of the black grime and dirt is embedded and probably won't come off without sanding, but I wouldn't worry about it.
Will
