I’ve searched a bunch of different threads and am seeing mixed opinions on whether or not the arrma D-safe pinions will fit on non-spectrum motors. Some have said the shape is slightly different with some shafts so it won’t work.
Since some of the spectrum motors seem to be re-branded hobbywing motors, I’m thinking these pinions may fit even if they don’t work with other brand motors.
I’m trying to fit a 33 tooth D8 pinion on a hobbywing 56113 motor with an 8mm shaft. I know there are plenty of standard bore options but I don’t really like the idea of relying on a little grub screw for brakes on such a heavy rig.
Has anyone fit one of these pinions on a Hobbywing 8mm motor shaft, and if so, were any modifications necessary? I understand the e-clip won’t work with it but I’m looking to see if the pinion will physically fit into the shaft. Thanks
