- Talion
Gpm makes good bulkheads (case where a completed diff, ring and pinion is). A diff case is thisCracked the front diff housing on my talion and am debating on getting one from hot racing that's aluminum and expensive or the stock plastic? Does anyone know the part number? Is it AR310854?
works front and back for noto kraton outcast and talion. https://www.gpmparts.com/arrma-krat...ar-gear-box-25-pcs-set-gpm-mak012-p-9312.htmlOk so I cracked the bulk head. You guys mentioned GPM and Vitamin. Do you have links by chance?
