- Mississauga
- 4x4-Mega
- BigRock 4x4
- Granite
- Typhon 3s
Running a 20T pinion. Any thoughts?
Ehhh. . . I got a 30mm el cheapo fan I can stuff on there.Nice but I’d put a yeah racing aluminum ball bearing fan on the heatsink
Longer can motors tend to run cooler. No fan should be required, just another thing to break.Nice but I’d put a yeah racing aluminum ball bearing fan on the heatsink
But it's more likely will just fiddlestick my ESC, no? 100 Amps probably not good enough? Could get myself a 4S battery and try that out I suppose. But I will have to get a 26T and maybe add a fan. Gotta try it like that on 3S. The idea of getting 60mph sounds fun.Grp,26t,,an id hit it with 6s an watch temps.i run my 4068-2650kv on 6s an its rated. At 16.8volts max.it screams on 6s.overvolting cheap motors is a blast.
Yes you can get 60 mph with stock setup,difference between 60 and 80 is major.100mph rc will blow your mind.100mph rc looks like it's going 200+mph.insane.78mph is fastest ive got my 1/10,100mph is a challenge with 1/10.lightweight,slipper clutch makes it alot harder than 1/8 in my opinion. If you want to go 100 mph with stock 0.8 mod gears you will need 6s..the problem is 57t spur being only option.need smaller spur so you can fit bigger pinion.imo whats needed to go 100mph with. 0.8 gears are.But it's more likely will just fiddlestick my ESC, no? 100 Amps probably not good enough? Could get myself a 4S battery and try that out I suppose. But I will have to get a 26T and maybe add a fan. Gotta try it like that on 3S. The idea of getting 60mph sounds fun.
I think I was doing that with a 3200kv and the 20T but I have no telemetry(?) thingies . . . Er.. speed measurometers. . .
Like this. . . Yeah.
