ESC continuous blinking green
T-ROY
I’ve got a 3s Typhon and its been running fine for a while now. After cleaning and putting it up for a few weeks I plugged in a fully charged 3s5000 lipo and I’m getting a steady slow green flash on the esc. I still have steering control but no throttle response. Doesn’t matter what I do with switch A & B it doesn’t change. I’ve tried the fixes others on here and the internet have suggested to fix without success. Most seems to be blinking in a certain series, mine is single flash after another.
‘thanks for any suggestions.
GraniteFox
Delaware
  1. BigRock
  2. Infraction
  3. Outcast 6s
  4. Typhon 3s
Check your motor wire connections for any bare spots or shorts. Make sure the throttle trim is in center position. If all else fails factory reset the esc:
Factory Reset To reset the ESC to factory default settings, connect a battery, turn the transmitter on and then turn the car on. Press and hold the set button for 4 seconds and release. The Red and Green lights will flash simultaneously to show you have reset. Switch the ESC off and factory reset is complete.
Next step would be to pull the motor housing and see if the motor is bricked.
T-ROY
Throttle trim is centered, wires are all good and I’ve tried resetting the esc and the green light never changes.
It would help if I had paid more attention to the battery. Wasted a lot of time that ended up being a battery issue. 6s causes steady green blinking light. Lol! Installed the correct battery and all is good. Sorry for wasting your time with my screw up.
Av642
This was helpful for anyone with future issues. Thanks for posting this solution!
Jon NC RC
Keep it fun......SEND IT
In the stix…NC Mtns
  1. Kraton 8S
  2. Kraton EXB
  3. Mojave
  4. Senton 3s
All's well that ends well....
Always feel free to ask for help..... We are all learning
