ItAintAtoy
- Kraton 8S
I really needed another way to discharge some 3S/4S lipo's
Mojave has been on my list for quite a while, I thought I might as well make a build log, nothing fancy though, just the usual recipy for a new RC.
Parts list:
- Obligatory new car, with the widely coveted new-car-smell.
- Power plant and transmitter/receiver: hand-me-downs from the Kraton 8S
-> Spektrum 1250kV 4685 motor (previous gen with 5mm toothpick-strength shaft)
-> Spektrum 160A ESC
-> DX3 transmitter with SR6110AT receiver
- Servo: el-cheapo from the spare bin: DS Servo DS3235 Pro (https://nl.aliexpress.com/item/32702835900.html?spm=a2g0z.12010612.8148356.1.3fe17523WqKUI8) we'll see how it holds
- 24t pinion 5mm bore, mod1 safe-D
- M2C extended hubs (https://m2cracing.net/arrma/495-m2c-3160-arrma-17mm-hub-extenders.html)
- Proline Badlands 3.8 (https://www.prolineracing.com/tires/badlands-3.8-all-terrain-tires-mounted-raid.asp)
1st up prep-work and some installation:
- opened up the diffs, all 3 got the LSD-plates, rear is configured for minimum effect, center and front for maximum effect
- replaced stock diff oil with 50/250/20k front/center/rear for now, I'll need some testing to find out what oil weights and LSD-config suits me best
- motor fits easily, stuffed some heavy-duty packaging foam under the rear, maybe it helps to absorb the bad landings
- ESC needed a shave, bit too wide to clear the upper motor lead
- servo is a direct fit
- plenty of room in the receiver box for excess cables
- toughened up the body posts, again the packaging foam
Some pics below:
Parts list:
Some pics below:
