Brewcity414
King of questions
Finally installed the Bell crank ?. Took me awhile to finish but it's done. I find it pretty funny I have 2 short screws and I don't know where they go. ????
Yeah they are connected I didn't take a picture of the finish product. They are short flat top screwsThere are turnbuckles that attach to the bellcrank on each side. They aren't connected in your pictures. Probably what those extra screws are for.
It should look like this:
View attachment 28286View attachment 28287
Used the screws they provided which were 3. 2 for turnbuckles and 1 for the servo arm.Did you use the screws they provided or the original screws?
Did you do this upgrade too? If so would you say it’s worth it? I just did the front HR c-hubs and blocks. Still debating what else should be upgraded.
Then how did you end up with 2 extra screws???Used the screws they provided which were 3. 2 for turnbuckles and 1 for the servo arm.
Worth it for sure. Tightens up the steering. Get the aluminum pivot balls if you don't have those.
Adjustable motor mount I'd you want to run a larger pinion (other than 20).Anything else here a must have?
?? Beats me I looked over the car multiple times. They're flat top screwsThen how did you end up with 2 extra screws???
Do you notice a difference with the hubs upgradedDid you do this upgrade too? If so would you say it’s worth it? I just did the front HR c-hubs and blocks. Still debating what else should be upgraded.
Yup got that already. Are the rear wheel hubs needed? I’m tempted at those too since I replaced out the fronts already.
No ot won't.Stupid question, but will installing this on the 3S BLX help with rocks getting stuck in the stock steering crank? From the pictures, it looks like it mounts higher then the stop somehow? Or is this a picture of the 6S?
I was out this past weekend on some gravel and couldn't drive for longer then 5 minutes without getting a rock jammed in the stock steering. Trying to fish them out constantly sort took all the fun out things.
